CODES PANNES ABS WABCO Disco 300 Tdi
Page 1 sur 7 1, 2, 3, 4, 5, 6, 7  Suivant
Message par beslau le Dim 10 Jan - 17:27
Help,
Je viens de m'apercevoir après remplacement de la lampe témoin ABS au tableau de bord que mon ABS est en panne.
La lampe reste allumée en continue.
J'ai réussit à extraire les codes défauts clignotants sur la prise OBDII avec un shunt et y en a 5.
2-2 / 2-3 / 2-4 / 2-7 / 2-10
Quelqu'un à t-il la liste de correspondance des codes panne de l'ABS Wabco monté sur Disco 300Tdi ?
Re: CODES PANNES ABS WABCO Disco 300 Tdi
Message par beslau le Dim 10 Jan - 20:21
J'ai trouvé cette liste mais y a pas mes codes Evil or Very Mad
Code 2-6 - Faulty stoplight switch or wiring. Fuse A5 blown or not fitted
Code 2-7 - Continuous supply to ECU with ignition off. Faulty valve relay or wiring
Code 2-8 - No voltage to ABS solenoid valves. Faulty valve relay or wiring.
Code 2-12 - Front right, too large an air gap or the sensor has been forced out by exciter ring.
Code 2-13 - Rear left, too large an air gap or the sensor has been forced out by exciter ring.
Code 2-14 - Front left, too large an air gap or the sensor has been forced out by exciter ring.
Code 2-15 - Rear right, too large an air gap or the sensor has been forced out by exciter ring.
Code 3-0 to 3-9 - Open circuit in connection from ECU to solenoid valve in booster, or in ECU
Code 4-0 to 4-9 - Short circuit to earth in connection from ECU to solenoid valve in booster
Code 4-12 - Front right, wiring to sensor broken or sensor resistance too high.
Code 4-13 - Rear left, wiring to sensor broken or sensor resistance too high.
Code 4-14 - Front left, wiring to sensor broken or sensor resistance too high.
Code 4-15 - Rear right, wiring to sensor broken or sensor resistance too high.
Code 5-0 to 5-9 - Short circuit to 12volt in connection from ECU to solenoid valve in booster, possible earth fault.
Code 5-12 - Front right, intermittent fault with sensor or wiring
Code 5-13 - Rear left, intermittent fault with sensor or wiring
Code 5-14 - Front left, intermittent fault with sensor or wiring
Code 5-15 - Rear right, intermittent fault with sensor or wiring
Code 6-0 to 6-9 - Short circuit between two connection from ECU to solenoid valve in booster.
Code 6-12 - Front right, no output from sensor, sensor may have too large an air gap.
Code 6-13 - Rear left, no output from sensor, sensor may have too large an air gap.
Code 6-14 - Front left, no output from sensor, sensor may have too large an air gap.
Code 6-15 - Rear right, no output from sensor, sensor may have too large an air gap.
Message par Discool le Lun 11 Jan - 12:23
Quelle est la date de mise en circulation de ton disco ?
Message par beslau le Lun 11 Jan - 14:39
il est de mai 1997.
ECU ABS réf.AMR5557
Message par Jensen le Lun 11 Jan - 17:25
beslau a écrit:Help,
ahhhhh bon il t' faut un lampé témoin pour t' dire qu' ton ABS n' marche pas Shocked sur tout avec ce temps de m*rde. lol!
Je ne trouve pas tes codes non plus! http://www.bba-reman.com/landrover_fault_codes.htm scratch
Commence par nettoyer les capteurs de rue, vérifie ci il y un bon terre sur le module ABS, Les freins sont il bien purge?Il y a pas d'air dans le block ABS?
Masculin Nombre de messages : 1406
Message par beslau le Lun 11 Jan - 17:46
Bon après recherche sur le net, j'ai trouvé les correspondance de tout les codes ABS pour Disco series I .
2-2 et 2-3 = défaut sur le relais de puissance de la pompe ABS
2-4 = défaut de la pompe hydraulique ABS
2-7 = défaut sur relais K101
2-10 = interruption masse borne 31
Après diagnostic sur mon disco, j'ai tout contrôlé résistances et tension entrée/sortie, je m'apercois que le relais moteur pompe K102 est HS.
Que je n'ai plus de sortie +ubatt sur la borne 8 qui commande le relais.
La pompe tourne bien si je shunte le relais K102 entre 30 et 87.
K101 et ca vient pas du faisceau.
Masse borne 31 est OK.
J'ai remis un relais K102 neuf mais les défauts ne partent pas même après avoir fait la procèdure d'effacement.
Je pense bien que mon boitier ECU est HS
Twisted Evil
Message par Bruce le Lun 11 Jan - 18:01
fallait acheter un transporteur mdr
Message par Dadou17 le Lun 11 Jan - 18:32
Simple avis perso :
S'il n'est pas couplé à un ETC, c'est plutôt un bien ....
L'ABS est une grosse daube pour citadin qui ne sait pas freiner autrement qu'en montant debout sur la pédale... Si ça ne tenait qu'à moi, je ne l'aurais sur aucun de mes véhicules... Et je ne regrette pas d'avoir appris à conduire sur un véhicule sans DA, sans freins assistés .... bref, du "pur", où c'est TOI qui décide et qui apprends (à tes dépens parfois pale ) le BON geste au BON moment....
Entre autres, sur un terrain meuble et glissant (neige, terre grasse ...) sans ABS, le freinage forme un bourrelet de matière devant ta roue qui formera une cale et permettra un arrèt bien plus aisé qu'avec l'ABS, qui lui, relâche tout et te laisse partir dans le décor affraid..
Mais bon, je conçois que tu veuilles que les fonctions normalement disponibles sur ton Disco soient en ordre de fonctionnement... ceci dit, pour être efficace, si tu répares, prévois le petit inter qui va bien Wink
Message par beslau le Lun 11 Jan - 18:50
S'il n'est pas couplé à un ETC, c'est plutôt un bien .... NON
Mais bon, je conçois que tu veuilles que les fonctions normalement disponibles sur ton Disco soient en ordre de fonctionnement... BEN OUAI, mais le souci dixit le manuel d'atelier Land Rover, le freinage est différent car y aurait pas d'assistance quand l'ABS est HS.
Ca m'énerve, j'ai horreur quand ca marche pas correctement, faut que je trouve...
scratch
Message par Discool le Lun 11 Jan - 19:10
Bruce a écrit:fallait acheter un transporteur
Il est passé sur la 1 hier soir.
Message par roomone40 le Lun 11 Jan - 19:18
le disco freine quand même moins bien quand l'abs ne fonctionne plus,
il freine correctement mais moins "mordant" qu'avec l'abs.
et sur les discos 300 l'abs marche bien pas comme sur les ranges 3,9 avec son assistance électrique, qui déclenche n'importe quand (quelle daube ce système de freinage)
Message par beslau le Lun 11 Jan - 19:39
Les grands maux, les grands moyens !
Message par beslau le Mar 12 Jan - 5:54
Si quelqu'un a un boitier ABS dans son grenier ou pour faire un essai, je suis preneur sunny
Message par Domi17 le Mar 12 Jan - 5:56
beslau a écrit:Si quelqu'un a un boitier ABS dans son grenier ou pour faire un essai, je suis preneur sunny
ahhhhhhh...il a cramé suite aux essais ou bien ... ???? Suspect Sad
Message par beslau le Mar 12 Jan - 13:48
Il a dû cramer suite au relais HS qui était HS depuis bien longtemps, c'est pas mon diag ... t'inquiète
Message par rover17 le Mar 12 Jan - 16:57
scratch
Je crois que la perte de freinage sans abs ne concerne que le classic soft dash avec sa pompe haute pression - haut tarif ...
Message par Discool le Mar 12 Jan - 20:46
beslau a écrit:Bon après recherche sur le net, j'ai trouvé les correspondance de tout les codes ABS pour Disco series I .
Geographiquement, il est ou ton boitier ?
Message par rover17 le Mer 13 Jan - 7:11
Si l'ECU te gratte , il n'est pas loin
normalement , doigt qui pue au matin
suis paaaaaaaaaaaaaaaarti study
Message par beslau le Mer 13 Jan - 7:46
Il est situé côté passagé en bas à droite
Message par Invité le Mer 13 Jan - 17:22
Tu as une référence? faut que je passes voir un pote pour un réservoir pour Mr Discool, je pourrais regarder en même temps dans son tas de discos
Message par beslau le Mer 13 Jan - 17:42
DAM,
Merci pour la propo, voici la référence AMR5557
Message par Discool le Mer 13 Jan - 19:04
DAM-NC4X4 a écrit:Tu as une référence? faut que je passes voir un pote pour un réservoir pour Mr Discool, je pourrais regarder en même temps dans son tas de discos
bravo bravo Ca tombe bien j'ai plein de mains samedi pour le monter. ange
Message par Bruce le Mer 13 Jan - 19:33
un tas de disco ???
Tiens tiens vla un truc qui pourrait etre interessant !!
Message par roomone40 le Mer 13 Jan - 19:43
Bruce a écrit:un tas de disco ???
occupe toi du tiens d'abord et après tu pourra t'occuper des tas...
Message par Bruce le Mer 13 Jan - 20:03
Bah justement, il me faudrait un tas (de pieces, pô une fille hein) pour remettre la greu un peu plus prop' !!
..... nan finalement t'as raison, je le laisse en mode fracassé, je l'aime comme ça !!
(ps, grace à l'ami Ludo, j'ai put refaire le diff' arriere, et remettre de l'huile un peu partout ou il y en avait besoin !! )
par contre pas de CT, RDV ce matin, banc de mesure en panne..... je roule donc dans l'illégalité sans CT.... No ..
